Refuses to print please help
It refuses to print. I tried everything I can think of please help
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi
Have you tried the following
Connecting it to WiFi
Making sure ALL colours have ink left as if one runs out it won’t print
Make sure the paper door is closed properly
Try connecting though a usb cable
Make sure it doesn’t need a firmware update
If none of the above works let me know and we can further investigate
Bu yanıt yardımcı oldu mu?
It doesn’t print just printing blank sheets
No imprime solo imprimiendo hojas en blanco.
@jayeff imprime en blaco. los cartuchos son nuevos
Les cartouches sont neuves mais ,e signal couleur clignote et l
́impression ne fonctionne pas
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 30
Her zaman: 1,447
2 Yorum
What have you tried? "I tried everything I can think of. . ." does not help us help you. We need a list of what you have tried and how as in what did you actually do.
For example did you run "HP Print and Scan Doctor for Windows"?
And is HP Deskjet 2600 the correct model number? HP lists models 2600/2675/2676/2677/2678. Which is yours?
mike tarafından
check everything I can think of nothing works, paper comes through as if printing but blank
Marie Taboada tarafından
