Will not boot. replaced power supply, still only 1 diagnostic light
Replaced power supply and memory, but iMac 20 still won't boot up. Only 1 diagnostic light
Bu iyi bir soru mu?
Bu iyi bir soru mu?
This sounds more like your drive has failed if you are seeing the screen and an folder icon is shown with a blinking question mark.
Taking the display off will impact the onboard LED's as the screen won't vibe wired in so while LED #1 is lit it only tells us power is getting to the logic board, as you also altered the RAM we can't rule out if the RAM is good of fully inserted. I would go back to the original RAM to see if things are working.
Bu yanıt yardımcı oldu mu?
No mattem what I have tried, the computer will not boot up, absolutel no activity, onthe than the one diagnostic led. I am considering replacing the logic board but would lie an expert's opinion before I do that.
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 7
Her zaman: 50
Can you give us a bit more here. What happened to the system? Did you get a power outage or lighting strike nearby?
Dan tarafından
It was a slow process of not booting up. Held the on button for a few seconds, and then would boot normally. Finally reached the poin it would not boot at all.
Wallace Hamilton tarafından
