Ana içeriğe geç
The XV20 series of the Toyota Camry is Toyota's 6th generation of the Camry sedan.
88 Soru Tümünü görüntüle
My Camry takes awhile to shift into gear
At times my 2000 Camry will not shift into gear right away when I put it in drive. When it finally does the car will jerk. Is it a transmission problem?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
You should probably check the level on your transmission fluid. My VW New Beetle does the same thing when it's low on transmission fluid.
To check the fluid, drive the car until it's fully warmed up. Park it on a level surface. Put the gearshift in Park, set the emergency brake and leave the car running while you check the fluid. Pull the dipstick out, wipe it off, then insert it again and immediately remove it and look at where the fluid level is on the dipstick. If it's low, add the appropriate fluid a little at a time until the dipstick reads full. Do NOT overfill it!
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
linz3favs sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 6
Her zaman: 57
