W124, 1984-1995/96 Mercedes-Benz E-Serisi versiyonu için Mercedes-Benz'in dahili şasi kodudur ve aynı zamanda resmi olarak E-Serisi olarak adlandırılan ilk nesildir. W124 modelleri 1984'ten sonra W123 modellerinin yerini almış ve 1995'ten sonra yerlerini W210 E-Serisi'ne bırakmıştır.
Kuzey Amerika'da W124, 1985 ile 1996 model yılları arasında satılmıştır.
my '92 300E i6 has started to act up . Hard start and acts like the timing is retarded, then starts and runs fine. Sometimes the throttle needs a soft touch or it stalls. My guess is a sensor but I don't know where to hunt for one..
Update (07/20/2022)
replaced both water temp sending units on the head. Car starts and runs fine till it gets to operating temp, then it stalls and backfires. It is not running hot, water level is fine, lower and upper hoes are hot so it isn't a sticky thermostat. I'm stumped.
Without knowing what you tried, that can often be attributed to dirty fuel injectors or bad spark plugs. Check the spark plugs and see if they are dirty, and if they are just replace them and rule out the possibility. As well as that, you may want to run something like Techron through the fuel system and see if that helps clear out the injectors. You can do both at once, or one at a time. Same with the air filter; check for dirt, and replace the filter if it's dirty.
Those Benzes also tend to have a wire throttle body (sometimes called a DBW throttle), so check the wire and throttle body aren't damaged. You can also hold the wire down by hand and you do this with the engine idling, not hold it and then start. If you hold it down, don't do it too long - 15 seconds max. You want to see it sustain a load, not test the entire RPM range.
The other option is to try an Italian tune-up as well, if you can legally do 60-80mph and keep the engine RPM high (and can be safe while doing so). Sometimes if just Techron fails, you need to combine it with an Italian tune-up. Where I'm from, fast driving is mostly normal, so someone doing an Italian tune-up isn't be unusual but YMWV on how "normalized" speeding is. It's also kind of gas intensive, so erm keep that in mind a bit. These older i6 engines don't drink as much gas as a S600 with the M120, but it's a definitely a factor during the gas crisis.
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
4 Yorum:
It is still on the trailer and I'll take a look at it Sat. I need to finish the propane truck I didn't get to today. Thanks for your tip, not sure what you mean by a "wire " throttle body but maybe when I get into it it'll be obvious. I've been driving this car for 3 years and this is the 1st problem it has given me. I'll update you when I figure it out.
It usually runs on the front or back of the engine, sometimes the middle. It's pretty obvious once you know what to look for. Generally, on the i6, it's on the front if it has one.
Sur ma Mercedes w124 e250 elle démarre très bien le ralenti elle le tien bien mais une fois que je vais rouler au bout d'un moment là voiture va brouter perdre en puissance jusqu'à fumé blanc et s'éteindre et il faut attendre ~10 min avant de pouvoir la redémarrer pour qu'elle recommence plus loin
2 Yorum
This question was migrated from https://meta.ifixit.com/Answers.
iRobot tarafından Paylaş
E320 don't start the work turne but the engine don't and there is no electricity on spark plugs.
Jean Louis tarafından Paylaş
