Ana içeriğe geç
Google'ın üçüncü nesil Pixel markalı akıllı telefonu ve markanın "çentikli" ilk telefonu. 6,3 inç QHD+ OLED ekran ve 64 veya 128 GB depolama alanı ile gelir. Nearly White (Beyaz), Just Black (Siyah) veya Not Pink (Pembe) renk seçenekleriyle mevcuttur.
Part for insulation tape?
Changing my battery due to the phone overheating and I noticed the insulation tape was torn. I cannot seem to find a replacement part for this anywhere. Can anybody point me in the direction of the part or a workaround to fix it?
Resim
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi
I wouldn't worry too much about this tape as it docent appear to be connecting to anything,heres what I would do!
try your best to straighten it out and get some non-conductive tape such as sellotape or electricians tape to put on top any that should fix your issue the best I can be fixed as I don't know of anywhere that would sell you a custom cut piece of this type of tape.
if you have anymore questions please ask
hopefully this helps
Bu yanıt yardımcı oldu mu?
Puan 1
7 Yorum:
This is what I was thinking of doing but had one thing holding me back. That insulation tape seems to be connecting to a heat sink from the battery to keep the board cool. Will electrical tape be able to transfer the heat from the battery to that heat sink?
tarafından
@Justin O
I don’t think it would matter too much as tape is horrible for transferring heat(that sort of thing wouldn’t make a difference in a cooling system)when its that thin,I think the tape is more just part of the manufacturing process rather than a essential part of the phone so the electrical tap will do just fine:-)
tarafından
Thanks, going with the electrical tape for this!
tarafından
@Justin O
That great:-)
tarafından
I tried using some metal foil tape, thinking it would conduct heat better, but now my GPS isn't working. I think the foil is shielding, reflecting, or otherwise interfering with GPS satellite signals. So don't use metal tape!
tarafından
2 tane daha yorum göster
Yorum Ekle
To anyone else watching this thread, this isn't regular tape. This is a graphite thermal pad.
Puan 0
Yorum Ekle
Yanıtını ekle
Justin O sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 31
Her zaman: 824
