Doesn't torn on . No fans working no hard drive sound
No fans spinning also I can't hear the hard drive sound just the LID of the power's on then of. There is no life on the device at all , It's charging though.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi
Try a full power refresh and check if that resolves the problem.
Here's the maintenance and service guide for the laptop.
Go to p.63 & p.78 to view the necessary pre-requisite steps and then the procedure to remove the main battery and the RTC battery respectively.
Once you have removed the RTC battery, measure its voltage. It is a 3V Lithium battery and usually lasts about 5-6 years. If it is <2.5V DC, replace it.
Bu yanıt yardımcı oldu mu?
I forgot to say what causes this problem. I removed the battery while the system is updating. I'm worry if I have to replace the hard drive or something like that
@Aka Maru
It should at least turn on i.e. fans etc and not boot into Windows if there was an update failure.
Try disconnecting the HDD from the motherboard (use the manual I linked) and then check if the laptop starts.
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 6
Her zaman: 57
