Ana içeriğe geç
LTE-enabled variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
Panic (cpu 0 calller) after battery repair
Did a battery repair on iPad 5 Cellular. After customer left with ipad it began to boot loop every 3 minutes. Shows PANIC (CPU 0 CALLER). I have already replaced the charging port but still the same issue.
Any ideas?
Thanks
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
This is likely some issue with a sensor checking in. This is almost always the case after a battery repair. It’s possible the new battery is defective. Or the battery connector on the board sustained some damage during the repair. The data pins in particular are prone to bend.
Can you post a copy of the full panic report? Or at least screenshots of the first page or so?
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
I have a picture of the panic log below
tarafından
@store0667 The panic you posted indicates pretty much what I expected. There is a battery sensor (TG0B) which the iPad is not getting communication from. The issue is going to most likely be the new battery, or damage to one of the pins on the battery connector. I would recommend taking the board out to inspect the underside of the battery connector.
tarafından
Yorum Ekle
Here is some of the Panic log.
Thanks
Puan 0
1 Yorum:
How did you disconnect the battery before disconnecting the screens? Or what did you use? Does as mentioned before sound like damaged pins on the board. A pain but remove the board completely and take a look for damage.
tarafından
Yorum Ekle
Yanıtını ekle
BP 667 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 23
Her zaman: 937
