After 25 years from the introduction of the first-generation Range Rover, the second-generation Range Rover—model-designation P38A—was introduced for the 1995 model year, with an updated version of the Rover V8 engine.
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
1 Yorum:
Test for actual spark on spark plugs and whether or not fuel is seen or smelled on plugs after failed starting attempts. Check for blown fuses as lack of fuel or spark narrows the problem down to one or the other. However, the lack of both may point to the crank position sensor as it generates timing signals the ecm needs to operate the entire EFI system.
F Dryer tarafından
