gray and green lines
it show gray and green how to i fix it
Bu iyi bir soru mu?
Hi Joe,
The best way to troubleshoot your issue is to connect the iBook to an external monitor and check if you have the same issue on the external. If so then your graphic chip is failing and it's time for a new machine. If the image is good on the external monitor then you need to replace the LCD panel or the LVDS (video) cable. You could begin by trying a PMU reset and a PRAM reset.
Bu yanıt yardımcı oldu mu?
+ Ralph
is going - there's a possibility of lengthening the life with a shim on the GPU or the fire trick... start saving for a new laptop.
If this answer is acceptable please remember to return and mark it.
Good Luck,
N.
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 813
