Can I replace the BATTERY?
Can I replace the BATTERY? If so, How?
Bu iyi bir soru mu?
Hi David,
As you've undoubtedly noted, there isn't a guide for your particular phone here on iFixit. However, I did find a YouTube video of the exact thing you want to do on this exact phone. Here you go.
How to replace the battery on Samsung Galaxy Note 20 Ultra 5G - YouTube
However, after watching the video, I was unable to see any difference between that procedure and the one for the standard (not 5G) Samsung Galaxy Note 20 Ultra. So my suggestion would be to follow the iFixit Galaxy Note 20 Ultra guide, as the instructions are quite a bit more detailed and informative than the video. If you run into anything in your phone that differs from the guide, then refer to the video if you end up needing more information.
Samsung Galaxy Note20 Ultra Battery Replacement - iFixit Repair Guide
The parts appear to be readily available on Amazon and eBay; you'll need a battery, battery adhesive and battery cover adhesive to do the job right.
Bu yanıt yardımcı oldu mu?
هل تبديل البطارية سيؤدي لحذف البيانات والاعدادات من الهاتف؟ أيضا لدي صوت تشويش من الهاتف هل بسبب البطارية؟
English Translation for those of us who can't read Arabic.
Will replacing the battery lead to deleting data and settings from the phone? Also I have a distorting sound from the phone. Is it because of the battery?
@abdulrhman47210, In general, no, since phones run on batteries, they are designed to hold onto their data and settings even when the battery is dead, so after replacing dozens of batteries myself, I have yet to find any lost data as a result, so the answer is no, you will not lose information by replacing the battery.
Likewise, the battery has no direct connection to the speaker, so if the replacement was done correctly, there would be no effect on it.
It's entirely possible a connector wasn't plugged in fully or perhaps a flex cable was damaged; you'd probably have to open the phone back up to find out.
@abdulrhman47210, بشكل عام، لا، نظرًا لأن الهواتف تعمل بالبطاريات، فهي مصممة للاحتفاظ ببياناتها وإعداداتها حتى عندما تكون البطارية فارغة، لذلك بعد استبدال العشرات من البطاريات بنفسي، لم أجد بعد أي بيانات مفقودة نتيجة لذلك، لذا الإجابة هي لا، فلن تفقد المعلومات عن طريق استبدال البطارية.
كما أن البطارية ليس لها اتصال مباشر بالسماعة، فإذا تم الاستبدال بشكل صحيح فلن يكون هناك أي تأثير عليها.
من الممكن تمامًا عدم توصيل الموصل بالكامل أو ربما تلف الكابل المرن؛ ربما يتعين عليك فتح الهاتف احتياطيًا لمعرفة ذلك.
نعم يمكن استبدالها وبسهوله
For those of us who don't speak Arabic, Google Translate says this means:
Yes, it can be easily replaced.
Kaled, thank you for wanting to contribute.
مرحبا تعطلت بطارية هاتفي واستبدلتها. ولكن يوجد لدي الآن صوت تشويش من مخرج الصوت. ملاحظة التشويش موجود منذ ان تعطلت البطارية. لا أعلم ما هي المشكلة وكيف إصلاحها.
وشكرا
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 15
Her zaman: 1,514
1 Yorum
مرحبا، تعطلت بطارية هاتفي واستبدلتها. ولكن يوجد لدي صوت تشويش من مخرج الصوت ولا أعلم ما المشكله او حل ذلك. ملاحظة صوت التشويش موجود منذ أن تعطلت بطاريتي. هل يوجد حل لذلك وشكرا
Abdulrhman Assiri tarafından Paylaş
