Put in a new blade SSD in it and it gave me a black screen!
I put a PCIe blade SSD in it and it worked, what happened is that it gave me a black screen problem after I put it in.
The system starts normally it is just that the screen is black you can even see the apple starting.
I put the PCIe and the system started with Catalina but at the time of restarting to install Monterey it gave me that problem.
Update (08/11/2022)
@danj so this port cannot be used with this ssd and with a hdd at the same time
Bu iyi bir soru mu?
No, thats not what I'm saying! Both can be populated with the correct drives! But thats the rub! Make sure you have the correct drive installed. If the image is the drive you are using it should be just fine! Samasung 128GB MZ-DPC128T/0A2
Dan tarafından
