Hi Justin,
I spent a bit of time poking around on the internet, and here's what I found.
First of all, it appears that model RCT6513w87DK is called a Galileo Pro rather than a Viking Pro; that may have contributed to your difficulty in finding a replacement screen.
I was unable to locate any screens using the manufacturing information (XianChuang M115WSBN40-03A), unfortunately. I did find that it appears the first three numeric digits of the model number are supposed to indicate the screen size; in other words, the "115" part of M115WSBN40 stands for 11.5 inches.
However, I did come up with a couple of them on eBay that should work. The search worked much better leaving off the last two letters DK from the model number. You'll have to take a look at them for yourself and decide if they're the right one.
RCA Galileo Pro RCT6513W87 11.5" Genuine Tablet LCD Touch Screen w/Battery
11.6'' LCD Display Screen for RCA 11 Galileo Pro RCT6513W87 Panel free ship #JIA
The first one is a complete display assembly with digitizer and battery (used), while the second is just the LCD itself; you were specifically asking to find an LCD, so I don't know if you need the digitizer as well or not. If that was the case, the digitizer is also available on eBay; it looks like it's running about $15 USD new like this one.
For RCA Galileo Pro 11.5'' RCT6513W87DK Touch Digitizer Screen Replacement
Hope that helps get you going again!
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
İptal
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
3 Yorum
Justin Orange, do you have it apart already? Any markings on the back of the LCD? I hate RCA for using LCD's that are so difficult to find. I can find some for the RCT6303 but am not sure about compatibility.
oldturkey03 tarafından
Second @oldturkey03's comment; I had a laptop that I simply could not find an LCD for until I opened it up and found the manufacturer and their part number for the screen itself. After I had that I was able to locate several other devices that used that same part and ended up finding one that was used on a different laptop.
Jerry Wheeler tarafından
@oldturkey03 I found on the back XianChuang M115WSBN40-03A. I also attached an image of the inside.
Justin Orange tarafından
