Ana içeriğe geç
Samsung Galaxy A20, Nisan 2019'da piyasaya sürülmüştür. 6,4 inçlik bir ekrana ve arkasında çift kameraya sahiptir.
Constant overheating when idle
My Samsung Galaxy A20 has had constant overheating issues recently. It will normally be idling or undergoing light use before closing all apps and then shutting off due to overheating. It happens multiple times per day and will occasionally have no issues some days. The thing is that sometimes the phone is genuinely cold prior to shutting down due to overheating. The only way to turn the phone back on is by entering recovery mode and booting the device from there, and then it will be fine for a few hours before encountering overheating issues again. I have a feeling that it may be an issue with the thermal sensor but I am not sure. Does anyone have any suggestions or have encountered this issue before?
Bu iyi bir soru mu?
Puan 0
2 Yorum
Did you try to reset your phone? Any hidden app or malware running in the background might be possible.
tarafından
The issues continue to arise in safe mode and I have no plans of performing a factory reset on the device. Others who have had similar/identical issues that have performed a factory reset continue to have overheating errors. I ended up removing the thermal sensor and that solved my issues. Thank you for your comment.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Ok, so I ended up following the advice found in this thread: A50 won't charage or turn on - Overheating icon
The issues I had were identical to this person and I performed the fix by removing the three small PCB components. Additionally, my ability to charge the phone had not been impacted. However, you can easily find a replacement charging port PCB on Amazon for cheap.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Larsen sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 31
Her zaman: 762
