Ana içeriğe geç
Samsung Galaxy A22 5G, Samsung Electronics tarafından Galaxy A serisinin bir parçası olarak geliştirilen ve üretilen, orta segment Android tabanlı bir akıllı telefondur. Telefon ilk olarak 24 Haziran 2021'de piyasaya sürülmüştür. Telefon, üçlü arka kamera kurulumu ve 90 Hz ekran ile gelmektedir. Bataryası 5000 mAh kapasiteye sahiptir; bu da iPhone 13 Pro'nun bataryasından %62 daha büyüktür.
Fingerprint scanner not working
The button is working properly but the sensor is not working.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 5
5 Yorum
It's f42 5g but it's not working but after restarting it's starts working for few minutes only.
tarafından
Sensor not work button is ok
tarafından
Fingerprint not working sencer
tarafından
Please working my fingerprint option Please 🙏 😢 Please
tarafından
Finger print not working
tarafından
Yorum Ekle
5 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@siddhantsen @gulfamkhan @fathimaraihana the very first thing you want to do, is to tell us what you all have tried to fix this. You have to determine if this is software or hardware related. A couple of common things to do, is to do a soft reset first. Then check for any software updates. Make sure you have the latest software for your phone. So go to your phone's settings menu, then look for the "software update" or "system update" option. If there is an update, download and install it. Next clear the cache and data of the fingerprint scanner app. You should also remove and then add your fingerprints once more. For more of all of this, check Samsung's advice on here
If none of this worked, you should consider replacing the fingerprint scanner. In the case of your phone the fingerprint scanner and the power button are combined. Since there are no guides on iFixit for this (yet) use something like this video to replace it. Remember that you need to purchase a proper replacement for your version of the A22 (SM-A226B, SM-A226B/DS, SM-A226B/DSN) to ensure compatibility. You can purchase those at many places online. Pick a vendor that meets your expectations.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Görsel içeriğini görün:
Resim
Puan 0
Yorum Ekle
My phone fingerprint not working
Puan 0
Yorum Ekle
Yes is now working as manual
Puan 0
Yorum Ekle
مشلكة لايوجد البصمة a22
Puan 0
Yorum Ekle
Yanıtını ekle
SIDDHANT SEN sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 38
Her zaman: 2,981
