Colored, varying lines along the screen. What do I need to replace?
See the following link for a picture of the problem.
The computer is Late 2008 15" MBP 2.4Ghz. I replaced the HDD numerous times and upgraded ram to 8GB.
Problem
- Lines change color, disappear and reappear in random intervals.
- Lines do not vary by tilting the display
- External display works OK
- Upon inspection, logic board connection of LVDS cable appears fine. No frays or indications of damage. However, I did not verify the LCD connection of the LVDS.
Questions
- What are the chances of problem being resolved by an LVDS cable swap ?
- It is my understanding that the problem is with the logic board of the LCD since sometimes the LCD would come back to normal. If LCD itself was damaged this wouldn't be possible. Is it possible to replace ONLY the logic board?
- Basically, should I replace the LVDS, the LCD or the entire display assembly? And if I should replace the LCD how do I determine the backlight type ? (LED/CFL) ?
I know similar questions have been asked, but I couldn't find if anyone had success with LVDS swaps or if replacing the LCD is an option, hence the posting. The display assembly is too ^&&! expensive (~600) and new MBP are around the corner in Q2 2012. Awful timing.
Thank your for your time.
Bu iyi bir soru mu?
2 Yorum
+ VERY well written question. I wish they all were written so well. The backlight on this is LED. Does applying pressure at the top of the screen, front or back, seem to resolve the problem? What country are you in? Are there any local electronics/TV repair shops that work on LCD TVs locally?
ABCellars tarafından
-Applying pressure to the bottom middle of the back side of LCD in the form of a whack just FIXED the problem. I believe it will come back after I restart or in a short period tho. Thanks for that
-I am in Turkey, there are electronic repair shops around.
kerimonder tarafından
