Kenwood Multione Motor Control Help
I have a Kenwood Multione that has stopped working. The motor control board made a pop board was charred underneath. I have now sourced and replaced the control board. The mixer powers up ok , the light is solid white but when I turn on the mixer , no motor movement and I can hear the relay clicks on the control board and the white light then flashes. Has anybody else had this issue ? I have tried to get support in the UK but no one will talk technical or supply any service manuals. Truly awful service other than wanting to charge m £90 + parts . I suspect that whatever blew on the original controller board may have damaged something else. Does any body now how I can test the motor on its own ,,,Does it have an inbuilt capacitor etc .. It is really poorly made
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
@robrolley any chance you can post a couple pictures of your boards and the motor connections? My concern would be that the motor may have gotten damaged. Can you get to the motor brushes with a multimeter? Mevcut bir soruya görsel ekleme
tarafından
Yorum Ekle
