Ana içeriğe geç
The PowerMac G5 is a desktop computer first produced in 2003 by the Apple Corporation. This guide will review the repair process of an Apple PowerMac G5 model number A1047 EMC 2061 from 2004. It was discontinued in 2006 as part of the Intel switch first to developers then consumers.
197 Soru Tümünü görüntüle
How can I remove the HDD in the upper bay?
I'd like to add a second drive to my G5 1.8. The problem is that the existing drive is in the upper bay, and the cables for the 2nd drive seem to be behind the drive. I did look at the question on removing the drive in the upper bay but could not understand the answer (as did someone else who posted a reply). How do you remove this drive without hitting the enclosure?
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
There are two pull levers on the side of the drive that lock it in place. They kind of blend in but take a close look and pull them. There is no outer door on a G5 for a second drive. That's how you can tell from the external if it is a Power Mac G5 vs an Intel Mac Pro.
Bu yanıt yardımcı oldu mu?
Puan 4
1 Yorum:
Thanks, but I find I don't need to remove the upper drive after all. At the bottom of the caddy are the 2 connectors+cables for the other SATA drive. You just pull them out and you're good to go.
tarafından
Yorum Ekle
Yanıtını ekle
dangold sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 566
