Ana içeriğe geç
ASUS TUF Gaming Laptop - i5-8750H ve Nvidia GeForce GTX'li FX505D-DBQ234T. Üretim Tarihi: Mayıs 2019.
ASUS FX505DU-MB53 Will Not Power On...
I was using my laptop on a zoom meeting, when it said that it had 10% remaining. I plugged it in and went on with the meeting. Shortly later the device went blank and shut off. I checked all of the connections on the charger and it still did not even show any indicating lights. Is there a good way to safely check the charger functionality? Or is is something else. Thank you in advance for your help. :)
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Joesph Dunne you want to check your charger first. Use an voltmeter to check the output. Positive probe from the voltmeter into the barrel hole and negative probe on the outside. If you are unsure how to do that post an image of the connector with your question so we can explain it better. If your charger has the right output (19.5V) you know it is working. then check your DC adapter on your Asus make sure that the center pin is okay and that it is all clean. After that you will have to open your computer and check the voltages on the inside of the DC connector. Start with the easy stuff first. Also, do not forget to try another outlet in the house just in case that is not working correctly.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Thank you! I did the checking... The charger works but the port is not giving any readings. I will try to replace the DC-In board but if that does not work, I will take it to a shop.
tarafından
Yorum Ekle
Yanıtını ekle
Joesph Dunne sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 15
Her zaman: 817
