Ana içeriğe geç
Charging/ Lightning port on working
My charging port will not work to charge my phone. Headphones do not work with Lightning port either. Right now must charge phone wirelessly only. Can't find lightning port replacement part or instructions
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
if your in the us try mobilesentrix, uk/europe try headlane.co.uk
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Hi
See this as something else to try In the meantime while you are seeing about getting your port fixed through the link that @tech_ni thanks fully provided:-)
Get a torch/flashlight and shine it into the port to check for dust and debris
If there is any get a sewing needle or some tweezers and carefully remove the dust and debris in the port(it can be surprising how much can fit in there!)
If that doesn’t work, turn your iPhone off and try a very small amount of isopropyl alcohol on a clean toothbrush and scrub away gently and the port to remove any corrosion that may stop it from charging,leave it to dry for a 30mins-hour just to be safe(just don’t get any on the lip between the screen and the chassis incase it gets in!
Hopefully this helps
Any questions please ask
Puan 2
Yorum Ekle
Yanıtını ekle
aaronroesler sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 34
Her zaman: 469
