Why washing maching keep noising while spinning?
My Lg washing machine keeps noise while spinning. It won't make any noise during washing. Just only on drying the clothes.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
LG washers beep at the end of each cycle to indicate that they are done, and can typically be silenced by pressing the beep button on the front. Other reasons for a washing machine to beep include running out of water or if something has been jammed into it.
A front load washer is a machine that washes clothes based on a programmed cycle. The timer on the machine may have been set to time out and cause an alarm. This is a safety feature that has been put in place to ensure that people don’t forget to turn off the washer. If the timer hasn’t been set, it may be due to a power outage or circuit failure.
If you don’t want your washer to have a beeping party, it’s crucial to know why your washer keeps beeping. Only then you’ll be able to fix it.
To fix your washer you can try the following things (don’t call the service provider just yet):
* Check if your machine is getting water
* Recheck if the lid is properly closed
* Redistribute the load
* Make sure your machine is properly balanced on the surface
* Check if the water is properly drained (if it’s close to spinning)
Now, let’s get into the reasons why your washer’s beeping at you.
Bu yanıt yardımcı oldu mu?
I lg turbo washing machine noise while spin I think something as been stuck in how to clean it remove inside like coin or other think
Son 24 Saat: 10
Son 7 gün: 53
Son 30 gün: 169
Her zaman: 4,169
