Ana içeriğe geç
Samsung'un onuncu amiral gemisi Galaxy telefonu, Mart 2019'da piyasaya sürüldü. Android 9.0 (Pie) ile birlikte geliyor.
Screen stopped working after battery replacement
So I just replaced the battery in my Samsung Galaxy S10. After installing the new battery and the charging coil, I turned the phone on to confirm it still worked. Everything looked good, I unlocked the phone, made sure the touchscreen worked fine, and turned it back off. Then I glued the backplate back on.
I set the phone down with books for an hour to dry like the instructions said, then when I go to turn it on , the screen never turns on. It buzzes, and I get notifications, but the screen is just completely black.
Any ideas?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Hopefully the cable going to the LCD from the board became disconnected which should be a quick fix. If that is not the case, it is possible that the OLED panel of the display was damaged which would give the symptom of the phone powering on vibrating/making sounds but not showing anything on the display.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
i have similar problem, replaced the battery but while checking found out that the screen is working improperly. Flashing , touch doesn't react always and everywhere. It's been about a 2 hours science replacing. I believe that the problem could be in amount of alcohol that I put while replacing. Idk, hope it works in the morning.
tarafından
Yorum Ekle
Have you used ifixit adhesive remover liquid to soften the glue underneath the battery? Since it has Acetone in it, even a tiny seepage of the liquid to the oled screen underneath the battery can kill it since oleds are made with organic materials (polymers).
Puan 0
Yorum Ekle
Yanıtını ekle
Matthew sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 36
Her zaman: 1,914
