Ana içeriğe geç
4 Kasım 2017'de satışa sunulmuştur. Model A1865, A1901. GSM ya da CDMA olarak 64 ya da 256 GB kapasitelerinde, Gümüş ya da Uzay Grisi renklerinde satılır. ("iPhone 10" olarak da telaffuz edilir.)
My bottom speaker is not working
I dropped my phone and my bottom speaker now its not working but when I shake my phone or give it a little hit the speaker start working again what should I do?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
My kids play something on setting and my phone speakers are not working
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi Ahmed,
Well, it seems we can be pretty sure something got either broken or shaken loose in the drop. There are three parts you're going to have to look at to figure out what's wrong with it.
The first is obviously the speaker itself; it could be damaged and would need to be replaced.
There is a guide available here in iFixit that will give you step by step directions on replacing the speaker.
iPhone X Lower Speaker Replacement - iFixit Repair Guide
Secondly, it's possible the connector for the speaker got knocked loose. This doesn't seem like a high probability, though, as it has a retaining bracket over the top of it to prevent just that sort of thing from happening. Regardless, you'll definitely want to check it and make sure it's plugged in solidly. Here's the connector you'll need to take a look at.
If you just want to check the connector, follow the instructions in the speaker replacement guide shown above and stop at Step 26.
The third possibility is that the dock connector that connects the speaker to the motherboard got damaged.
iPhone X Lightning Connector Replacement - iFixit Repair Guide
Personally, I would probably go ahead and replace the speaker; they're not expensive and it's one of the simpler repairs on an iPhone X. If that doesn't do the job, then the dock connector is the only other thing that's in the path between the speaker and the sound chip on the motherboard, so that would be what I'd replace next if a new speaker doesn't fix the problem.
iPhone X Lower Speaker Görseli
Kılavuz
Zorluk:
Orta
1 - 2 hours
iPhone X Lightning Connector Görseli
Kılavuz
Zorluk:
Zor
1 - 2 hours
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
ahmed omer mustafa sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 3,956
