Ps4 pro not recognizing controller via usb
… i have a ps4 pro with a scuf vantage 2 ps4 controller which worked up till 2 Weeks ago… although it turns on, and i can get to the emergency mode by holding down the power button at the front for 2 beeps, i can pick various things, including output resolution and rebuilding the database, initializing the ps4( don’t wanna do that) and restarting the ps4 pro… i rebuild the database, the ps4 pro restarts, and i’m told to plug a micro usb cable into the controller and the other end into the 1st front usb port on the ps4 pro which i did and press the ps button… and nothing happens… i’ve tried using the 2nd usb port on the front, same result, even tried one of the back usb ports.. no difference… i know the micro usb cable is new and it supports charge and sync ( so i presume it supports data too)… i’ve tried resetting the controller and its connection… no difference/no change.. can’t do bluetooth at the moment, can’t change connection methods…i’m guessing the problem is with my ps4 pro… so i guess i’ll have to take it in and get it fixed…
Bu iyi bir soru mu?
