Ana içeriğe geç
DeLonghi ESAM kahve makinelerinin farklı serileri bulunmaktadır. Makinenin alt kısmında genellikle ESAM 3xxx, ESAM 5xxx veya ESAM 6xxx model adını içeren bir etiket bulunur.
Delonghi Caffe Corso Flashing Water Tank Error
Hello, my Caffe Corso worked fine until a few weeks ago when it stopped making coffee. I took the entire thing apart water pipes, pump, valve etc. and found the primary issue - a huge rock of limescale clogging one of the smaller pipes - and removed it. Water now flows, however, only for circa 10 seconds and suddenly it cuts out with the water tank light flashing. I can try again and it will work but again, only for circa 10 seconds. Does anyone have any ideas aside from the usual one of turning the steam nob because this only works for 10 seconds too. For the same reason, it cannot be properly descaled, although I've manually ran this. Thanks!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum:
Did this tips helped out...I also have this problem
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Have a look for the flowmeter. There is a guide for the ECAM series, the flowmeter for ESAM is the same.
DeLonghi ECAM Serisi akış ölçer (flowmeter) değişimi/revizyonu
(In German, use Google translate)
The test mode could bei helpful:
DeLonghi ESAM xxxx - Test modu
And: there is a "finger" on the rear side of the drip tray. If it is broken, the machine does not "feel" the closed tray.
2nd and: worst case: a clogged heater...
DeLonghi ESAM Family Görseli
Kılavuz
Zorluk:
Orta
DeLonghi ECAM Series Akış ölçer (flowmeter) değişimi/revizyonu Görseli
Kılavuz
Zorluk:
Orta
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Lewis Bateman sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 19
Her zaman: 1,713
