Ana içeriğe geç
Repair and disassembly guides and support for dish washing appliances.
705 Soru Tümünü görüntüle
Bottom spray arm doesn’t work.
Bottom spray arm not working, replaced diverter. Didn’t fix the problem. Took the diverter disc out and and the bottom spray arm works but with the decreased water pressure the dishes don’t come clean. Any ideas?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum
Hi @chewdog4
What is the make and model number of the dishwasher?
tarafından
Kitchen Aid Dishwasher
KDTM354 DSS5
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @chewdog4
It may be a problem with the wash motor not creating enough pressure to drive the spray arms.
Here's the tech sheet for the dishwasher.
Besides showing how to run the diagnostics there are strip circuit diagrams for each function. On p.4 there is the wash/rinse motor circuit and it shows the motor windings resistance values which may be worth checking to see if the motor is OK or not.
Bu yanıt yardımcı oldu mu?
Puan 3
17 Yorum:
Sounds way over my head. It acts as though it’s “stuck” on top rack only cleaning.
tarafından
@chewdog4
Did you try running the diagnostics as described in the tech sheet and checked if there were any error codes displayed?
tarafından
I did but I can’t make heads or tails of it.
tarafından
@chewdog4
What error code(s) are you getting?
The Clean LED will flash the code - two flash patterns with a pause between the two. This pattern is repeated 3 times
e.g 5 flashes - pause - 1 flash - pause - 5 flashes - pause - 1 flash etc = door stuck open - see p.7 onwards
tarafından
9 clean flashes
tarafından
12 tane daha yorum göster
Yorum Ekle
You may have to replace the spray arm itself. I know it’s counterintuitive but these things spin, jerk and get banged up all the time. Bottom line, they are one of the fastest wearing part in your dishwasher. That’s what I ended up doing on my Kenmore after trying several things like you did. The spray arm is the culprit.
Puan 1
1 Yorum:
The spray arm works without the diverter disc.
tarafından
Yorum Ekle
Yanıtını ekle
Tad sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 16
Son 30 gün: 63
Her zaman: 649
