Ana içeriğe geç
batterie fully charged Roomba instructs me to cha
Hi
I charge my Roomba fully, charge light is on green turn the Roomba on it runs fir 10 seconds and instructs me to charge again, I check the batterie and its fully charged, I have cleaned all contact point
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
@ymaes2020 sounds like a battery issue. Fully charged means that you can see it has the required voltage but you do not know how the battery does under a load. The only way to be sure that your battery is working to specs is by doing a load tech which means you will need special tools and software etc. I suggest you start off with a new battery. If nothing else you can use that as a known-well starting point should any further troubleshooting be needed.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Gary sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 91
