Ana içeriğe geç
Logitech Wireless Desktop MK710 (2013 çıkışlı) için onarım rehberleri, sökme bilgileri ve sorun giderme yöntemleri.
Water damage of LogitechK710 keyboard
I have a logitech K710 keyboard that I spilled a water on the keyboard 2 weeks ago. I immediately turned it over and drained the water, I set it to dry for a day (flipped over), and then I took all the keys off and dried any moisture left. But still there are certain keys that aren't working, most importantly the space bar doesn't work. What's the next step? I'm hesitant to take it into get repaired as it was only a $60-$70 keyboard/mouse set.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi
The best thing to do here is to open it up and give everything a good clean with isopropyl alcohol and some cotton buds/q tips
When water comes into contact with electronics it can cause it to corrode which can cut the flow of electricity
Once fully dismantled and cleaned inspect for any burn marks and broken traces as if you find any you can restore them by running a jumper wire or using diver conductive paint
Once open if you could upload some photos using this amazing guide it would be amazing
Mevcut bir soruya görsel ekleme
Hopefully this helps
Any questions please ask
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
wrestlerxtr1 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 345
