Ana içeriğe geç
iPhone not charging after installing replacement battery.
Hey all. I just installed the ifixit replacement battery into my iPhone 11. It now starts up fine and everything seems to work just fine, except for the battery.
Of course, I lost all the battery health information, but I expected that. It's also showing 0% charge, and will restart randomly after a couple minutes. I have it plugged into a charger, but it does not show a charging symbol. It does make the sound and small vibration when it's plugged in though.
I tried force restarting it several times as well, it did nothing. Did I get a bad battery?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 5
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
If your old battery was still charging you will need to open the phone back up and check the battery connector is seated properly also check that you haven’t nudged or knocked off any of the small components around the connector. After reseating the battery connector if it still will not charge you will need to try another replacement battery as the one you purchased is probably faulty.
 If you’re old battery stopped charging and showing percentage the same as the replacement one you will have a board issue that will require a reputable repairer to diagnose.
Bu yanıt yardımcı oldu mu?
Puan 4
2 Yorum:
The old battery is charging fine and ok but i don't know what happened with the new one
tarafından
It just happened to me. what I did was to open again the phone, disconnect and reconnect the battery connector and it worked.
tarafından
Yorum Ekle
Just ran into this same issue on my iPhone 11 after replacing the battery myself. I removed and reconnected the battery connection and that solved the issue. One of the contacts must have been out of alignment and/or not in contact correctly.
Puan 0
Yorum Ekle
Yanıtını ekle
Hayden Shaw sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 19
Son 30 gün: 79
Her zaman: 6,119
