Ana içeriğe geç
A1708/EMC 3164 — Released June 2017, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar).
547 Soru Tümünü görüntüle
Why is my MacBook wifi not working and only shows an exclamation mark
Hello, so i have a problem with my macbook pro 13. For some reason I cant turn on the wifi and in the wifi icon it show an exclamation mark. In the network preferences as well doesnt show any wifi interface. Does anybody knows how to fix this issues. Thanks in advance.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
2 Yorum:
Hi, I have the same exact problem on my MacBook Pro 13” 2015. I’ve tried all software related solutions, and even tried disconnecting then reconnecting the wires on the network card inside to no avail. Have you found a solution? Cheers!
tarafından
Same situation is happening with me as well.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hi Ahmad,
You can access Wireless Diagnostics by searching for it in the Spotlight search function or by doing the following:
1. Hold down your Option key and click the wireless icon (the Wi-Fi symbol) in the status menu at the top of your screen.
2. Select "Open Wireless Diagnostics..." from the dropdown menu.
3. Select "Monitor my Wi-Fi connection" from the pop-up window and click "Continue."
Bu yanıt yardımcı oldu mu?
Puan 0
4 Yorum:
Hello, thanks for the help but for some reason i can't open wireless diagnostic. When i click on it, it appears briefly on the dock and then it disappear.
tarafından
Hi Ahmad
Try reset your wireless settings
1. click the apple icon -> system preferences -> Network -> select wifi connected and not connected -> click minus icon and apply
tarafından
i tried doing that but it keeps saying
Preferences Error
There was an error in Network preferences
tarafından
@albert13228 - this series uses a chip Vs a independent AirPort board. Sounds like the chip has failed. I would inspect the logic board for damage.
tarafından
Yorum Ekle
Yanıtını ekle
Ahmad Rafi Fajarsyah Nurhani sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 36
Son 30 gün: 203
Her zaman: 5,241
