Laptop power on issues
SD card usb lan cable
Issue
Update (09/16/2022)
This white cable is damage i want this
Bu iyi bir soru mu?
Issue
Bu iyi bir soru mu?
You will need your exact model number as explained in the HP parts surfer link:
https://partsurfer.hp.com/partsurfer/
You could also download the Maintenance and Service Guide for your model.
Just type in your exact model number and "Maintenance and Service Guide".
This is one possble site:
https://mans.io/files/viewer/419782/1#na...
They may only sell the the cable with the whole part as in your photo.
Bu yanıt yardımcı oldu mu?
Perform a hard reset.
Inspect the AC adapter, cables, and adapter (DC) port on the laptop for damages.
Verify that the wall outlet is working correctly.
Check the LED indicator on the AC adapter.
Connect a known-good AC adapter.
Disconnect the laptop from the docking station (if applicable)
Run a diagnostic test on the system board
Regards,
Son 24 Saat: 4
Son 7 gün: 6
Son 30 gün: 18
Her zaman: 370
1 Yorum
A little more detail please if you can?
mike tarafından
