Ana içeriğe geç
*LG telefonları şarj etmek için USB Type-C Kablo Tertibatı *Şarj kutusu, Travel Power Adapter EAY64469128 olarak adlandırılır
How to fix it?
Not able to charge my phone
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi
Cables can be repaired but a lot of the time it isn’t worth repairing as with cables they struggle to last due to how they are used and how compact they are but it really depends what’s wrong
If it’s not charging make sure your device is plugged into a wall adapter that’s is compatible with your cable
It could also be damage related too so you will probably have to take the end off and desolder the cables to the pads that they belong to, the only issue is this is very hard and it could be a connector issue too so if you don’t know what the issue is for sure you could find yourself going down a rabbit hole
So my advise would be to ether dell or recycle the cable and buy a new one
Hopefully this helps
Any questions please ask
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Repair my usb phone cable
Puan 0
Yorum Ekle
Yanıtını ekle
Shubhashis Kayal sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 15
Her zaman: 372
