Ana içeriğe geç
Düşük fiyat segmentine hitap eden Asus F550/X550 serisinden bir model. Dört çekirdekli bir Pentium işlemciye sahiptir.
How to upgrade ram?
I have conflicting info on this F551MAV-DB02-B on how much ram it can use/maximum. Crucial says 12G, and that it only has one slot and that the ram IS removable.
First, is it removable/replaceable? Second, just how high can I go with ram, I'm guessing just an 8G stick, which would improve this system a lot. Third, just how/where/what do I have to remove to get to the ram to replace it?
FYI, Crucial has this to say about ram:
  • CT8G4SFS824A
  • Configuration ID: CT9393524
DDR4-2400 • CL=17 • NON-ECC • SODIMM • 260-pin • 1.2V • 1Rx8 • PC4-19200
Thanks for any help/insight you can provide.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum
from what i can see on 2 separate sites it says max ram is 4gb
tarafından Paylaş
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Those are really good questions, an easy way to asertain the information you require is to locate your chipset information. The chipset on the motherboard determines a lot of things, one of those things being the amout of RAM that you can install and utilize. There is also a helpful program called CPU-Z which will give you a lot of useful information. But, if you are feeling brave, you can attempt to remove the bottom cover and locate the RAM yourself. Just by looking you should be able determine if it is soldered or not.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Decir que el módulo de la memoria RAM (4Gb.) Standard en este modelo (solo uno) alojado en Slot- Desmontable. F551MAV-BING-SX5522B del 2014. BIOS 506( raro es que no estén en el mercado módulos de 8Gb. para ampliar) Como ahora a Xxxxx Fabricantes les da por la reduflack/quitar todo, conectores, unidades xx, memoria la justa, etc. Subir precio y bajar cantidad y calidad.
LA última versión de la BIOS-(516)
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Richard Ernst sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 11
Her zaman: 475
