Desolder and replace relay’s
Hi,
I am about to replace some relay’s on the PCB for a jacuzzi. The legs on the relay are a bit too far between to be able to melt the solder, equally on all pins, to remove the relay.
Any tip so I can melt the solder on all pins at the same time and remove the relay? I need to be sure not to overheat the PCB or other component’s.
See attached.
Regards
Bjørn
Bu iyi bir soru mu?
