Oil leak top of machine
Chef Premier.
Oil has appear inside the top cover around/ below the drive from the gear box to the electric motor, near to the blender drive.
Bu iyi bir soru mu?
Chef Premier.
Bu iyi bir soru mu?
@dhpreece your mixer does not use oil. What you have going on here is that the grease in the gearbox separates to solids and liquid. it is that liquid that gets pushed through the gasket. Time to take it apart and replace the grease. There are difference in the gearbox etc. with the Kenwood mixers. If you can provide us with the model number of yours or attach some good pictures with your QUESTION. I would expect your Premier to be a KMCXXX
Essentially these guides Kenwood Chef: Planetengetriebe SER1018 değişimi (Almanca) should work but you may have slight variances.
Kılavuz
Zorluk:
Çok kolay
2 - 5 minutes
Kılavuz
Zorluk:
Zor
2 - 6 hours
Bu yanıt yardımcı oldu mu?
Check the gasket as shown in the second photo, Step#3 of this guide:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 67
Her zaman: 3,369
