Ana içeriğe geç
Repair guides, disassembly, and troubleshooting information for the first generation Sony PlayStation 5 DualSense controller, successor to the DualShock series. Identified by model number CFI-ZCT1W and motherboard model BDM-010.
What would cause a bumper button to not work
I have a PS5 Dualsense remote with a suddenly non-functioning R1 button.
  • No physical damage to the remote from dropping/excessive force has been exerted
  • No water damage
  • The black plastic part of the button is in the correct position. Removing to access the silicone part of the bumper button and pressing with a pry tool/screw driver does not work
  • R2, L1 and L2, as well as all other functionality is perfect
  • The remote is a v1 remote
I've tried disassembling the remote and investigating, nothing out of the ordinary to report and I'm at wits end. Any guidance would be appreciated.
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Ended up being a microtear in the ribbon cable through some of the middle connections, which obviously affects the R1 button in particular.
Easy enough to replace, but I can imagine that with the design of the right ribbon cable being more exposed it could potentially lead to more issues over the left one
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Had to buy a new L1 bumber it goes in normally & even works but won’t stay in the holder whatsoever. Falls right out when I turn controller upside down or tip it over confused tried everything what could it be ?
tarafından
Yorum Ekle
How do you fix the micro tear
Puan 0
1 Yorum:
Replacement ribbon cables can be found on Amazon. Watch for the generation controller you have though as apparently there are several and some use slightly different cables.
tarafından
Yorum Ekle
My L1 has the issue even after replacing ribbon cable with new one iam still facing the same issue don't know of it's hardware to software issue
Puan 0
Yorum Ekle
Yanıtını ekle
Jarod Kurland sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 28
Son 30 gün: 120
Her zaman: 5,060
