Ana içeriğe geç
Released on November 22, 2005, the Xbox 360 wireless controller is the primary game controller for the Microsoft's Xbox 360 home video game console.
How can I fix separation between the front and rear cases?
I tossed my controller against the ground and there was a popping noise and the front and rear cases separated on the left side. It didn't separate very much, but is there any way to push them back together?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
There is a good chance you broke one of the mounting posts. I would say follow one of the guides to separate the controller case halves and inspect for damage. If you can, carefully bend back any damaged plastic pieces. Heating the plastic part that's bent may help prevent breaking, but plastic doesn't like to be bent or unbent. Epoxy may also be your friend here. You might be able to restructure or reconnect broken parts.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Mark Schmidt sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 614
