Ana içeriğe geç
Replacing Ceiling Fan That Has Separate Light Fixture
I have a Hampton Bay fan on my porch, as well as a separate light fixture. They are both controlled by a Hampton Bay remote, and are both wired to the same wall switch.
My light works well, but the fan's rotation is way too slow and a new capacitor didn't fix it. The fan is old and not the style I want, so I'm prepared to replace it.
Is there anything I need to consider about replacing the fan, knowing that I still want the light to be controlled via remote? I'm worried that if I replace the current fan with a new one, I won't be able to control the light anymore.
Resim
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi Kenny,
I would think your best shot at this would be to buy a Hampton Bay brand fan as a replacement. There are two ways I see this working for you.
  1. The new fan has DIP switches that can be set to match the frequency of the old remote, which you could hopefully keep using.
  2. You could keep the existing wireless receiver and install the new fan with it, in which case you can be confident the new fan will still work with the remote you already have. In this case you could probably get away with buying any brand of fan you want.
Resim
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Thank you so much! I’ll give that a try.
tarafından
Yorum Ekle
Mi ventilador no funciona con el control
Puan 0
Yorum Ekle
Yanıtını ekle
Kenny Coleman sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 30
Her zaman: 623
