Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
1 Yorum:
Billiejean Burk I would definitely replace the water inlet valves and check the little screens that are on the hose connection side. Make sure those are clean. You can get the FH error if your washer does not drain properly so check that the Drain pump operates properly (maybe clean out the coin trap). After that you need to verify that the Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch. Check the flow meter operation as well since it can give this error in the rinse cycle as well.
Last but not least, we will need to know your exact model number so that we can get you the datasheet. That will tell you how to run a self check on your washer.
oldturkey03 tarafından
