Ana içeriğe geç
Engine noise from 2011 Seat Leon
I have a 2011 1.6 Litre Seat Leon Diesel. The engine has been louder than usual and there is a vibrating when sitting in the car. The vibrating is worse when the clutch is depressed. Does anyone know what could cause this?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@johndoe177 this "The vibrating is worse when the clutch is depressed" could be a bad bearing or a worn pressure plate. Check your clutch a bit better and see if the noise sounds more like a grinding coming from the clutch area. Of course it could also be a vacuum leak as well as 100 other things that may cause your engine to develop a vibration. Consider having the OBD scanned to see if it throws a code.
Bu yanıt yardımcı oldu mu?
Puan 4
Yorum Ekle
Yanıtını ekle
John doe sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 20
Her zaman: 1,234
