Ana içeriğe geç
Released in May 2020, the 13" MacBook Pro features quad-core Intel 10th generation Core i5 and i7 processors, and Intel Iris Plus integrated graphics. (Model A2251/EMC3348 with four Thunderbolt 3 ports)
Newish MacBook Pro Battery not charging
The battery on this relatively new Mac Pro is not charging. Everything else is working fine. The ports and the charger have no issue. This is the diagnosis from TG PRo. Thank you for your help.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Looks like the battery just failed. It happens unfortunately. Most of the time batteries degrade over time but sometimes they just die suddenly. If you're still covered by warranty or Applecare+ I would have Apple take a look. Otherwise, installing a new battery will likely get you up and running again.
Bu yanıt yardımcı oldu mu?
Puan 3
3 Yorum:
Could it be a faulty connector? Is it worth opening up the unit to disconnect /connect the battery to the motherboard?
tarafından
It would be unlikely based on what TG Pro says. But it's certainly easier than installing a new battery. Definitely worth giving a go. Bear in mind the battery has 2 connections on this model. A small cable which communicates battery data and a little tab that comes off the logic board and screws into the battery management board. You'll have to disconnect the cable and remove the T5 screw under to remove battery power.
tarafından
Thank you! That is very helpful.
tarafından
Yorum Ekle
Yanıtını ekle
Amrita sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 10
Her zaman: 233
