Ana içeriğe geç
Mini tarafından üretilen mini otomobiller. iFixit'in Mini ile hiçbir bağlantısı yoktur ve Mini aşağıdaki içeriği oluşturmamış, desteklememiş veya sponsor olmamıştır.
AUX cable , 2011 mini cooper?
Why doesn't any AUX cable fit in the factory port of my 2011 mini cooper? Its driving me crazy trying to figure out how to play music thru my minis stereo. I've tried the Bluetooth & it dosent work. I've also tried to use the USB port, which it dosent recognize/connect AT ALL. I use an Android phone and trying to use a basic USB cord, also tried to use a Aux cord (3.5mm) and the plug won't even go in the hole, lol.. I've tried googling the Anwser to no avail.. Do i need an adapter or something?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @blasphemaevil,
Just wanted to be a little controversial with your username, eh? Okay, cool. :)
Anyway, there are different sizes for audio jacks as you just found out. Most phones use that standard 3.5 mm jack you've got, but there's also a smaller 2.5 mm jack in somewhat common usage. Fortunately, the industry recognizes this and makes adapters that will fix you right up. Here's an example from Amazon that should get you going.
Amazon.com: Vention 3.5mm Female to 2.5mm Male Audio Adapter Converter Premium Quality Headphone Earphone Headset 2.5mm to 3.5mm 3 Ring Jack Stereo or Mono 2 Pack : Electronics
The main thing you have to be aware of is the number of rings on the tip of the adapter; they need to match the number on your plug. The one I listed has two rings, along with the tip and the sleeve, making four electrical contacts in all. One is for ground, one for left channel, one for right channel and one for a microphone. Look at the number of separate metal parts on yours and count them up; the replacement you buy needs to have the same number yours does. Ignore the black bands; those are insulators to keep the different parts from touching each other and just count the separate metal sections.
No idea why Mini decided to go with the smaller jack, but hopefully this will get you sorted! Good luck; let us know how it works out.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
@dadibrokeit Ill give it a good & get back to let you know how it works out!
tarafından
Hi there I know this is an old post but I’m wondering whether this worked for you as trying to find the right thing to buy to connect my phone to my car
tarafından
Yorum Ekle
Yanıtını ekle
blasphemaevil sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 45
Her zaman: 3,153
