Ana içeriğe geç
Xbox Series X|S ve Xbox One ile çalışacak şekilde tasarlanmıştır
Why is it beeping?
I recently moved and set my xbox back up. When I power it on the external hard drive makes a beeping sound and powers off. Can this be fixed or do I need to replace it?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
When the drive is beeping, that means there is a power issue or it's at the end of it's life. There's some troubleshooting that can be done to see if it's just a power issue
# (The easiest) Disconnect the drive and unplug the cable from the disk and spray out all the ports. There might be some dust
  1. Try another cable. Some cables are better with power and data connection then others
Otherwise, you can run SeaTools. It's a software made by Seagate that diagnoses drives. You can download it here and you should be able to run a test on your drive to see if there is any corrupted data or see the hard drive's life
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Dread Head sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 25
Her zaman: 536
