Ana içeriğe geç
Mayıs 1999'da tanıtılan 2000 model yılı Maxima (A33 olarak adlandırılır), Jerry Hirshberg yönetiminde 1996-1997 yılları arasında Nissan'ın La Jolla, Kaliforniya'daki tasarım stüdyosunda tasarlanan bir önceki otomobilin yenilenmiş halidir.
Idle its variable engine
Hi
Enybody its now way this problem its, work nomaly when the engine its cold with all rpm , but when the temprature its been 70 dgs celisius and more , its the variable idlle engine run with 1500-2000 rpm only..feels like a kenguru .the onlye errorcodes its comming its P0 420/430 , its been delete many times, i think that have nothing with this problem too fo
https://youtube.com/shorts/VwiKqCwjzyc?f...
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
me only instead of clearing the codes I would suggest you check your catalytic converter as well as the O2 Sensors. The behaviour you describe, could definitely be caused by those.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
Have delete the codes some times and the o2 sensores have been replemented for few years ago and never have no problem with the emission , forget to wtite about the idle in start of the engine go the idle down to almost stop and uo agin , look like the airmassesensor its works in short time...
tarafından Paylaş
@me only yes I was thinking mass air flow sensor as well. My concern is that bad O2 sensors and a bad catalytic converter can do the same thing. You can check the O2 sensors and see if they are functioning. All you need, is to measure the amperage drawn by the sensor with a cold exhaust. It should be between 0.25A to 1.5 amp. Anything else shows they are failing.
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
me only sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 23
Her zaman: 507
