Ana içeriğe geç
Mayıs 2003'ten beri üretilen Gigabyte dizüstü bilgisayarlar için onarım rehberleri ve destek.
Black screen with vertical lines
Hi there!
So I recently purchased a Gigabyte G5KD laptop (i5-11400H / RTX X3060P) - it’s just over a month old.
I was watching Netflix in bed last night and all of a sudden the screen started rolling blurred grey streaks across it, then went black with nothing but these vertical lines appearing.
Resim
As you can see I plugged it into my monitor and it works fine, but the laptop display itself seems to be buggered. I tried resetting the graphics card but sadly I’m starting to think it’s a hardware issue - which is a crying shame considering how new it is.
Any clue what it could be? Is there anything I should do before I start considering taking it to get repaired?
Thanks
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi
Is it possible to use the laptops Integrated gpu instead of the dedicated one as if you can try that you can tell if it’s a gpu related issue rather than a display issue(if it does it on one gpu but not another you will know what one has the issue buts that quite unlikely)
At the moment it’s looking like a display issue but we need to confirm that by trying the above
Hopefully this helps
Any questions please ask
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Tried adding new ram?
Puan 0
Yorum Ekle
Yanıtını ekle
Leigh Ramsay sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 19
Her zaman: 789
