Backlight power cable / pinout question
I converted my 5k 2020 iMac into just a monitor using a converter board.
Unfortunately I now have some uneven LCD lighting along the very bottom of the screen as pictured.
During the "mod", I damaged one of the 12 (I believe) tiny power wires, but when I tested it before closing up the iMac, I didn't notice this and thought I was lucky with that wire being a ground connection or something.
I'm hoping to get confirmation from someone really knowledgable about these LCDs as to whether that is indeed the problem, because if it is, I may take it apart again and try to solder or replace that power cable.
But if its just other damage to the LCD/backlight, then I probably won't bother with it.
The power ribbon cable splits into two cables that plug into either side of the screen, underneath black adhesive tape. I didn't realize there were connectors under there and ripped up the tape, ripping the two 6-pin "jumper" things out of their sockets. Only one wire was damaged.
Resim
I
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
