Ana içeriğe geç
Ekim 2021'de piyasaya sürülen Google Pixel 6 akıllı telefon için onarım ve parçalarına ayırma bilgileri. GB7N6 ve G9S9B16 model numaralarıyla tanımlanır.
Pixel 6 touch screen less precise after replacement
I have had my Pixel 6 screen replaced after a big crack.
After finally fixing the fingerprint sensor issue, I still find myself with a major problem:
The touch screen is less "precise" when typing fast. Namely, when I am writing fast and touch the screen in two points almost simultaneously, it interprets it as a "swipe", and therefore misses the first of the two touches.
This had never happened before the change. Is this a known issue, or could it be a problem with the new screen itself?
Thanks!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
This is likely a defective screen. See if you can get a refund or replacement. If it was a cheap screen, it may just be very low quality.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Thanks, that was also what I thought. It was however not a cheap one, and was (according to the seller) an original piece. Will ask for a refund
tarafından
Yorum Ekle
I have this same issue and also when I call someone the screen flickers
Puan 0
Yorum Ekle
Hi. I don't have an answer, but I also got my screen (only the touch part) replaced by a third party (Pixel 6 wasn't launched in India) and have the exact same issue. How did you fix it?
Puan 0
Yorum Ekle
Yanıtını ekle
Davide Di Nello sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 15
Her zaman: 1,160
