What tools are required to replace the serpentine belt?
Toyota Corolla 2008
Bu iyi bir soru mu?
Toyota Corolla 2008
Bu iyi bir soru mu?
You will need a breaker bar with a 19mm socket. Turn the drive belt tensioner clockwise (toward the radiator) to relieve tension on the belt, and then remove the belt. Then return the tensioner to the unloaded position.
Bu yanıt yardımcı oldu mu?
Hi ,I need to Bye the large Hexsogon spanner that goes on tensioner so I can get the se serpentine belt of my freelander1 deise l 2006. 2liter. Thanks .Ray.
Hi Rob i have not got a answer from you from my last question ,,please could you send it has
Raymond you do see that this Q & A is 6 years old? Maybe you should ask your own question.
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 22
Her zaman: 6,678
2 Yorum
The 19mm nut to relieve the tension is just above the tension wheel. Very hard to see. I went to an auto parts store and asked to look at the tension bracket to see where it was located. Helped a lot.
Jeff tarafından
easy way to replace serpentine belt on a 1999 dodge caravan 3.8 engine
john tarafından
