Ana içeriğe geç
Learn about the skills that you might need to work on your device.
What product do you recommend for removing a smartphone battery?
What product do you recommend for removing a smartphone battery sticker? I wanted to get iFixit Adhesive Remover but I saw that it is no longer available. Last time I did it through a hair dryer, but I still risked ruining the battery a bit.
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi
See my answer as a extension of the amazing answer @guardian10 has kindly provided
IFixit’s adhesive remover is good but iFixits iOpener is also a great choice
A hair dryer works great too along side isopropyl alcohol
Also here’s a little tip:when prying battery’s up try your best to AVOID metal tools as they can puncture the battery if you aren’t careful
Plastic tools don’t have as high a chance of puncturing a battery but the risk is still there so it’s best to stick to the ones that are flat and don’t have any sharp edges
Hopefully this helps
Any questions please ask
Bu yanıt yardımcı oldu mu?
Puan 6
4 Yorum:
Thank you very much for your advice. Everything went well, however, now I have encountered new problems.
https://it.ifixit.com/Risposte/Visualizz...
Do you have any advice?
tarafından
@most99
Can you see any damage to the connector or cable
Also did you unplug it
tarafından
which one in particular?
tarafından
@most99
Sorry I should have said in the previous comment
I am wondering about the camera
tarafından
Yorum Ekle
While it is preferable to use Ifixit adhesive remover, you can use regular isopropyl alcohol to weaken the adhesive, then pry the battery up.
Puan 5
1 Yorum:
tarafından
Yorum Ekle
Yanıtını ekle
Gavino Santu sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 25
Her zaman: 269
