Ana içeriğe geç
Lenovo'nun B serisi ofis dizüstü bilgisayarları için onarım rehberleri ve destek bilgileri.
Boot menu empty and bios can't load default
Pls help me out. I have lenovo laptop with ssd and hdd in my hdd i install kali linux and ssd window. By my mistake windows was corrupt and now I can't boot it... The main problem is in my boot menu not any external internal device show only it show kali option which will boot and open grub menu of kali where I can have kali linux and window option. I can boot kali linux and it working file and as I tell u my window can't boot its show error.
Now problem is I want to install Windows again but can't becoz my bootablependrive not showing in boot menu and i try everything.But can't get help i open bios but i don't know how but i can't change anything in bios and i can't load default and eventually I bios boot order only kali is show. Usb hdd ssd nothing is showing. I also try with removing cmos battery for 1 hour so i thought it reset my bios then it will show my pendrive in boot menu but this also not work for me.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum
can you see if it says legacy or uefi in bios boot options ?
tarafından
Uefi but as I said I also can't make any change in bios.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi,
Press C when your GRUB boot menu appears to open the GRUB command shell. From GRUB rescue prompt using the fwsetup command you should be able to enter UEFI BIOS.
Once in UEFI setup, remove boot option for GRUB. This will restore Windows Boot Loader as the default bootloader.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Peter Parker sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 1,066
