My iPod Classic 80G battery cable broke. Can I use it while connected
battery cable connector broke
Bu iyi bir soru mu?
Bu iyi bir soru mu?
@star75 if you have broken your battery connector off the board and are wondering if your iPod will work while the USB cable is plugged in, then the answer is: Depends.
Your USB port on your computer will not work nor will the older iPhone power adapter. An iPad adapter may work. Personally, I use a Firewire power supply for those iPods and it will work without issues.
Check the answers to this question SOLVED: The Brown connector broken. - iPod 5th Generation (Video) - iFixit Different model but identical problem and essentially the same board.
Bu yanıt yardımcı oldu mu?
Try it, unless you try you won’t know. New batteries are cheap enough.
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 7
Her zaman: 88
